Tracker level fields
SA_10751312
3-Newcomer
Hi Team,
As of now, in PTC Codebeamer we have fields for line items inside the trackers, but a lot of customers are asking for the tracker-level fields or attributes such as part number, serial number etc etc.
As this functionality is not present in Codebeamer, we request you to consider this request and implement it in further releases of Codebeamer.
It is important to note that a lot of customers are asking for this functionality across the globe, and also the other ALM solutions has this functionality.
Incase of any further clarifications, reach out to @shaikraj.a@mgtechsoft.com
Thanks & Regards,
Shaik Raj Ahammad
     It would really help if you raise an Idea at - Codebeamer Ideas - PTC Community
This will allow other customers to collaborate and provide their point of view.
Kartik
A common workaround for the inability to add tracker-level fields is to create a root folder item in the tracker, and place all other items below that root folder item.  The fields of this root item can then be used to hold tracker-level information.
Hello @SA_10751312,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
