synchronization for deleted or disabled users in active directory
MM_10991077
Hello Community,
Is there a way to automatically disable a user in Codebeamer when the user is deleted or disabled in Active Directory?
We have found that there are many users who have been deleted from Active Directory but are still active in Codebeamer.
Manual disabling takes a lot of effort for us.
Any setting in application, script, API, etc?
thank you
Currently, Codebeamer does not automatically disable or delete users when they are removed or disabled in Active Directory (AD). Out of the box, Codebeamer can authenticate via AD/LDAP, but it does not sync user status (enabled/disabled) unless explicitly scripted or integrated.
To automate the deactivation of users removed from AD:
  • Use Codebeamer REST API to disable users
  • Script a comparison between AD and Codebeamer user lists
  • Schedule the script to run regularly
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
Shashi Preetham,
Hello pshashipreetham,
your suggestion helped me to complete my task.
Thank you very much!
