Link to Case: https://www.ptc.com/appserver/cs/view/case.jsp?n=15398519
Badr EL ANDADI
No you can't hide individual faces of a part only the entire part.
What is your usecase for wanting to do this?
@agarland
Thank you for your reply.
Customer was working on an AR based on that model and he needed to hide some sequences.
We found a workaround by solidifying the original model in STEP forma and convert it into Solid Parts in Creo Parametric and this helped him to unlock the situation.
Thank you
