Is there any way to change the color and intensity of the color that highlights part numbers in the sbom column? I have great difficulty seeing which number has been highlighted. Thanks to any one who can help.
Neal Lewis
Hi Neal,
Unfortunately that is not configurable at the moment.
\Is it the color of the highlight or the contrast to the background color that is not clear for you?
Adrian
Adrian,
It is very, very difficult for me to see the number that has been highlighted.
We use Hewlett Packard® EliteDisplay E231 displays and Dell® P2212H displays.
The only way I can see the highlight is to move my head so I am seeing the display sideways.
This means that every time I pick a part on a model, I have to stop and change my head position to see which part has been selected. It slows things down significantly.
Any suggestions to reduce this problem would be appreciated.
I will pass any suggestions on to the rest of the Technical Publications department and to the Engineering group.
Thanks.
Neal Lewis
Hi Neal,
Is it the same on all machines?
The reason i ask is I wonder if it's related to graphics drivers.
Maybe if you could attach a screen shot of the issue, that might help us understand a little better.
Adrian
Adrian,
I was wondering if you had received my Email.
I will not put screenshots on line.
They are proprietary.
Neal Lewis
