3 digit work offset
cncwhiz
2-Explorer
3 digit work offset
Can someone tell me where in the post I need to allow my post to output 3 digit work offsets. I need to use "G540, G550, G560...". When I output the g code it only output "G40, G50..."?
3 REPLIES 3
You need to add a FIL code to handle that...
Something like OFSETL = OFSETL+500
Hth,
Daniel
I think your problem is that the G register is set to output only 2 digits
to the left of the decimal. Open your Option File and go to the File Format
-> MCD File screen. Click on the G and change it to 3 - 0 for both Inch and
Metric.
Fred
_____
Ops...
