Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
How do you make the lines for the Flat-to-screen title block shown in this Wildfire 4.0 presentation? http://www.ptc.com/WCMS/files/51307/en/layers_in_combined_states.swf I can apply the text easily, but I do not see an option to add the lines to create the title block. Please help. Thank you.
What you do is create a symbol for you Titleblock and add it by way of Annotations. The way I did it was take my drawing format and make a dxf file of it and take it into autocad and delete everything except for the titleblock and then I bring it back into a Pro/E drawing and then create my titleblock symbol.
