Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi Shailesh, that´s apretty broad quetion. What do you want to know? Alias is not part of the ptc product suite and you will find tons of info on the web...
