Add feed and speed to a solid cutting tool
TonvandenHeuvel
Right now I'm busy with creating a solifd model that I like to use as a cutting tool.
I like to add the feed and speed to this tool So the tool every field in the tab with feed and speed.
I mean the tab from the cutting tools
Is it possible to do this?
1 REPLY 1
Yes, you can save Cut Data with the tool. However, this functionality may be a little more complicated than you imagine. You associate the Cut Data (feeds & speeds) with individual materials. (You can define this for multiple materials with each tool). However, you also need to set up appropriate directory structures and config options to make this work. See the Help files for more detail.
