I've been able to do this under actions->new->new graphic information element. However, my purpose is to use this image as a decal in Creo, and even though I can locate the file in Windchilll cabinets it does not show up as a decal. I can get the decal to work when I browse for it on my local computer, but the image disappears every time I close the program. That's why I'd like to pull it into Windchill. Is there a better way to set up decals to be permanent across sessions?
Hi Moses,
You can try setting the config.pro option save_texture_with_model to yes; this will store the image with the model. Otherwise set the config.pro option texture_search_path to the whole path of the texture directory; which could be located in Windchill.
Amit
Hi Moses,
Amit
Thanks Amit. That worked!
