Ahhhh!! The friday noob question.
dpilkey
Hello Gurus
wildfire 2.0
When adding dimensions we sometimes change from our normal arrow to a filled dot.
Our current procedure:
Point mouse at arrow we want to change--RMB--ARROW STYLE--FILLED DOT--DONE/RETURN.
My question: Is there a way to change the RMB selection menu so that I could put the FILLED DOT option right there.
Thanks to all
Donald
cprice
6-Contributor
(To:dpilkey)
No - PTC has no plans to allow a customizable RMB menu (at least from my
last discussion with them).
There actually is good reasoning behind this. Currently, the RMB menu
will only show the selections that can be done per the function the user
is performing. If you were performing some other function (like moving a
view, etc.), you wouldn't want to see the "customized" change terminator
to filled dot.
An accidental selection of that pick could foul up your intended
function (and probably confuse Pro/E to the point of crashing).
Better safe than sorry!
Charlie Price
Lead CAD Application Specialist
Diebold, Incorporated
330 490-4552
I wish I still had the functionality of 'flipping arrows' from pre WF
Best Regards,
Mit freundlichen Grüßen,
Atentamente,
Mitchell Smith
Product/Prototype Designer
ZF Sachs Automotive of America
Let's try this again. I know how to flip the darn arrows. I still do not like the way it way changed in WF. My M160 gives me nothing but grief when trying to move the witness lines and I do not like the pull down RMB menu that is now in WF.
I do no need help, I still just wish I had the functionality of 'flipping arrows' from before WF!!
Best Regards,
Atentamente,
Mitchell Smith
llam
2-Guest
(To:dpilkey)
You still have have the flip arrow functionallity i.e. right click flip arrow :
Select the dimension to flip arrow.
Move it just an very tiny bit and keep it selected
Now, while the dimension is still selected, click the right mouse button, without lifting
your finger from the left mouse button !!
