And another thing about Insert here...
brianlynn
Don't you think it would be easier if there was a pick in the RMB menu
when your mouse is in the model tree? 5 picks to do something that is
fairly common practice when you are examining someone else's model seems a
no-brainer to move it to the RMB menu.
Thanks again,
Brian S. Lynn
CAD Administrator/Designer
7 REPLIES 7
cfly
(To:brianlynn)
Well, sure - but that would be inconsistent with the Wildfire philosophy...
cfly
(To:brianlynn)
I've never said I lost functionality; however, most things that have changed
take an average of about a third more mouse picks and lots of moving the
cursor around the screen than they did before WF. At the end of a day of
intense modeling, and especially detailing, I have hand cramps. Oh, and
there actually is at least one bit of lost functionality - the detail module
is no longer WYSIWYG - the axes on the screen no longer match what prints
out. This is a HUGE step backwards, IMNSHO.
Another way to apply the insert function while in the model tree:
Carol you hit it on the head !!! I couldn't have said it better myself. The
"reduced screen picking in wildfire, has been compared to all know cad systems
and a 30% reduction is realized by making the switch to wildfire " This is a
direct quote for Dan Campbell at PTC the statement was made at the Atlanta Pro-E
conference 2 years ago. Dan if you are listening, sorry friend you are just
plain wrong. Example #1 why does it take 3 to 4 cancel operations to get out of
the wildfire sketcher as compared to 2 in 2001. This is a huge pain in the
butt !!! I have numerous examples but in general I have seen the mouse picks
go up at least by 1 pick... Not the reduction that Mr. Campbell of PTC
marketing promised !!!
H A R R I S C O R P O R A T I O N
Government Communications
Systems Division
HARRIS
Post Office Box 37
Mail Stop
102-9863
Melbourne
FL USA
32902-0037
Brian L. Taylor Phone: (321) 729-3781
ElectroMechanical Designer II Fax: (321) 729-3899
Radar 1A and 1B E-mail:
F35 Joint Strike Fighter
Assured Communications <http: www.harris.com="/> www.harris.com
This information is only intended for the use of the individual or entity named
in this email. If you are not the intended recipient, you are hereby notified
that any disclosure, copying, distribution, or use of the contents of this
information is strictly prohibited. If you have received this email in error,
please notify me and delete it immediately.
>> in the butt !!!
I always expect someone to respond "why do you need to cancel out of a
sketch ?". 🙂
Nonetheless, it happens to me a lot and I searched and found this mapkey:
But even if a 30% reduction is fact it STILL gives you 50% more mouse clicks
than almost any other CAD system! 😉
I believe this is what you should all be referring to in your attempt to
discredit Pro|E Wildfire as an improvement over previous versions.
