Annotation module is not activated
wathavy
Hi. I have one OneSpaceModeling PE installed working perfectly. One more installed which does not have Annotation module activated. Is there anyway to let it work? Thank you for your attention.
2 REPLIES 2
Not applicable
(To:wathavy)
Do you get any error messages when Annotation tries to initialize? Claus
wathavy
(To:)
Thank you Claus The solution you gave me worked. ----<Quote>---- Go to your user profile directory (typically something like c:\Documents and Settings\yourname\Application Data\CoCreate\<OSD_PersonalEdition>\14.50) and rename it. If this fixes your startup issue, delete the renamed directory. ----<Quote>---- Toshi
