Annotation module is not activated
wathavy
Hi. I have one OneSpaceModeling PE installed working perfectly. One more installed which does not have Annotation module activated. Is there anyway to let it work? Thank you for your attention.
Not applicable
(To:wathavy)
Do you get any error messages when Annotation tries to initialize? Claus
wathavy
(To:)
Thank you Claus The solution you gave me worked. ----<Quote>---- Go to your user profile directory (typically something like c:\Documents and Settings\yourname\Application Data\CoCreate\<OSD_PersonalEdition>\14.50) and rename it. If this fixes your startup issue, delete the renamed directory. ----<Quote>---- Toshi
