CAMU Error code -23
JoeH
2-Explorer
CAMU Error code -23
Does anyone remember what ERROR CODE -23 means in CAMU?
Thank you,
Joe
Joe Haines
Engineering Systems
CNH America LLC
500 Diller Ave
MS 631
New Holland, PA 17557
PH 717-355-3699
FX 717-355-4091
3 REPLIES 3
abruce
(To:JoeH)
Joe,
This usually means that the ODB_DAEMON process is not running on the
DB_DAEMON_HOST machine.
Check your .caddsrc/.caddsrc-local file for what DB_DAEMON_HOST is set
to, then run /usr/apl/cadds/scripts/db_daemon on it. You also may need
to check permissions, as the user that the ODB_DAEMON process is running
under needs to have write access to the _db file.
Best regards,
Andy Bruce
PTC Global Services
Manchester UK
JoeH
2-Explorer
(To:JoeH)
Turns out to be a corrupt assembly. Got an older copy from backups and it
comes up fine.
Joe
Joe Haines
Engineering Systems
CNH America LLC
500 Diller Ave
MS 631
PH 717-355-3699
FX 717-355-4091
fuerst
(To:JoeH)
Excellent follow-up.
