Hello all,
I have a customer that needs me to open a .CGM (Computer Graphics Metafile) file in ProE WF 4, make some changes and then exporting it out as a .CGM.
The problem I am having is that ProE does not see the file or does not recognize it.
Does anyone have any experience with this problem?
Many Thanks,
TCW
There is a trial if this kind of work is not constant.
Warm Regards
Guilherme Rocha - Tech Support Consultant
PLM Solutions do Brasil
“A goal without a plan is just a wish.”
PRO|E has this option when opening a file, you've said that PRO|E was not able to see the file, nowthat's weird, try to check the extension of the file and use the option "All files"in the "Open" dialog box.
but depending which software generated the CGM it can generate issues regarding different sizes from the original and imported/exported files in/from PRO|E, there is a document from PTC about it:
