Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Can PTC create a Pro/Mechanica forum? It would help in trying to sort through the mechanica posts. I know I can search, but it just seems beter for Mechanica to have its own forum. Thanks, Steve
Yes we really appreciate that posibility of the new Pro/Mechanica forum, if any nkows a guide to create a complete drop test analisys with eps foam we appreciate some feed back
