Can a mapkey delete itself?
Chris3
I tried recording it and nothing got recorded so I am guessing not. Has anyone played a trail file or otherwise deleted a mapkey?
Currently I am loading back in a blank mapkey over the top of the old mapkey which effectively deletes it. It still leaves it in the list of mapkeys though.
Jose_Costa
(To:Chris3)
I think it can, look at this example:
mapkey $F6 ~ Command `ProCmdUtilMacros`;\
~ Select `mapkey_main` `list_mapkeys` 1 `$F6`;\
~ Activate `mapkey_main` `DeleteButton`;\
~ Activate `mapkey_main` `CloseButton`;
It opens macro dialog, selects the desired mapkey, deletes it and close dialog box.
Just replace  $F6 with your own mapkey name in line 1 and 2.
Jose.
5 REPLIES 5
kdirth
(To:Chris3)
You should be able to delete a mapkey in the dialog box.  Remember, you must then save your mapkeys to keep the change.
You can also delete lines out of your config.pro file.
Jose_Costa
(To:Chris3)
Jose.
Did you pull that from the trail file or coerce the mapkey to record it?
Asking for a friend.
Yes, I did the cheating, I copied it from the trailfile.
Chris3
(To:Jose_Costa)
Awesome. Thank you.
