I am using ProE WF5 in a country in which I do not speak the language. But everything in ProE is in English. Except for the Help! I need to figure out how to do something (ie use Help), but I not only can I not read how to do what I need to do, I also cannot read how to change the language setting!
Can anyone help me out with this?
Everything is the correct language except for the Help. But I'm helpless without Help in the correct language ![]()
Hi
check the config setting for the followings
