Changing language of Help??
ThomasPhore
8-Gravel
I am using ProE WF5 in a country in which I do not speak the language. But everything in ProE is in English. Except for the Help! I need to figure out how to do something (ie use Help), but I not only can I not read how to do what I need to do, I also cannot read how to change the language setting!
Can anyone help me out with this?
Everything is the correct language except for the Help. But I'm helpless without Help in the correct language
Hi
check the config setting for the followings
yes*, no
Specifies the language for messages when you are running a non-English version of Creo Elements/Pro.
yes—Displays Help messages in the language set with the LANG or PRO_LANG environment variable.
no—Displays Help messages in English.
yes*, no
Specifies the language for messages.
yes—Displays messages in the language set with the LANG or PRO_LANG environment variable.
no—Displays messages in English.
