Hi all,
can you help me with a minor, but rather annoying issue i have with clipping a witness line. When i "create a witness line" for radial style dimensions, i cannot for the life of me put the end where i want it. You don't appear to be able to snap it to vertex or geometry by holding down the shift key & picking the witness line, like you can with linear type dimensions. The clipping of witness lines full stop, has become very tiresome in Creo 2, once again, far too many clicks of the mouse required, to get the job done.
Just discovered something else, you do not appear to be able to "create a witness line" for manually created radial dimensions, most annoying.
Regards
John
