Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Hi all, Is there a way to make "component outline" in Pro/E as can be done in "Product view"? (In shaded view - make colored body edges - outlined in black) this can be very helpful to quickly understand bodies with many features
I think what you want is to display edges when shaded... If that is correct do the following: View > Display Settings > Model Display > Shade and check the box With edges Steve D.
