Constant force spring model
AntonioVillanue
Does anyone have a model of a constant force spring? See image. How would you model this in Pro/E?
For example:
This was started with a Curve From Equation / Cylindrical with the relations:
x=2+t*2
r=t*360*5
z=0
Then create a Sketched Curve, copy the first Curve with Use Edge, add the end details, and use this Curve to create a Sweep.
Probably the easiest way is to create a Curve by Equation for the spiral and build from there.
For example:
x=2+t*2
r=t*360*5
z=0
