Hi everyone,
Is it possible to convert a Creo Parametric 3.0 file to 2.0?
I made some parts in Creo Parametric 3.0 and now, I want to use it in Creo Parametric 2.0.
Regards
You cannot convert a Creo3 part to Creo2, but you can open and modify them if you use the GCRI available from ptc's website.
Lukasz,
it is not possible, because files are not backward compatible.
Martin Hanak
