Anthony,
First, try searching for "Thread Note Formatting" in Pro/E's help section. I know how annoying it can be to use help unless you know exactly what PTC has named what you are looking for. Given your hole has *no* thread, I imagine this three word name may not have occured to you 🙂
It did not occur to me, anyway. I only now know where to find that in help because I founda TAN and TPI on the help documentation being incorrectin earlier versions of Pro/E. The link to the TAN you will want to read for the correction to the help filesis:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=/117734.htm
OK, now more specifically to your situation, try selecting the note with a left click and then hold down right click and then choose Edit Value. The text of the hole callout should pop-up in a text editor window. Odds are you won't find anything like the following in it.
n &CBORE_DIAMETER[.2] v x &CBORE_DEPTH[.2]This is an example of the type of verbiage that will display the counterbore information you are looking for. If you place it into the editor, you should get a counterbore callout in your note again. You may have to playwith it to get it to look exactly right since I don't knowhow the forum may munch the symbols that are interspersed between the CBORE callouts.I hope that helps.
Matt Yacono
Engineer II
Research & Development
(949) 727-7559
(949) 753-6270 fax
