Create chamfer with constant width
kdirth
Is there an easy way to create a chamfer with a constant width?
I would like to control the distance from edge to edge of a chamfer between varying surfaces.
2 REPLIES 2
TomD.inPDX
(To:kdirth)
For now, you probably have to leverage the new capability of rounds in Creo 3.
Use the round as a surface and use its edges to guide a sweep/cut as a variable section sweep.
...Or this (Creo 3 commercial version attached)
