Creating a new template(.frm)
ageorge-2
How to set the command for text font while creating a new template(.frm)
3 REPLIES 3
I believe the .dtl will set the defaults
If you need some thing different, place the text.
go back and select the text and then rmb and select text style
modify accordingly
Thanks Ron.
Have one more doubt..
Here we are creating a new .dtl file, in this how can we set the colors (rather making the System Color in Black and White)
create a .scl file (screen color??)
easy enough to do
File > Options
in the options window, select System Colors
in the config.pro, add:
system_colors_file <filename>.scl
I have several backgrounds: blue, black, white, and powerpoint
I use mapkeys to activate the different files, for example, I like to work with blue but when I create a window clip .png, I will first change to a white background.  when I am done, I will change back to blue.
