Creating new Bend Tables
RENEVDMERWE
Hi All How do I import/insert my own bend table.? Is there a certain way the formula has to be written? Does it matter if it is imperial/metric? Thanx
2 REPLIES 2
Rene, To create a Bend Table go to Edit>Setup>Bend Allow>Bend Table>Define. I suggest you look at the Help files: Help>Help Center>Sheetmetal, then Search for Bend Table. David
Does anyone have develop any bend table as per the diferent material or k-factor as per the industry requirement.
please share the details for making our bend tables (guide lines)
Thanks in advance.
