Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Leonid Creo 3.0 M010 should see the release of the new Plastic Advisor built on Moldex technology. You will be able to install and test it at that point. The old Plastic Advisor capability is not available in Creo 3.0 F000
I hope this addresses your question
Thanks in advance
Paul Sagar Director of Creo Product Management
Preview file
21 KB
