Creo3 - Finite friction or ground springs?
346gnu
Finite friction requires larage deformation analysis.
Ground springs require small deformation analysis.
... I can't have one if I have the other.
Is this correct?
gkoch
(To:346gnu)
Hi Charles,
I can confirm!
Found an internal SPR that states that finite friction requires LDA and another SPR confirms that all non-linear options (including LDA) are grayed out, when to-ground or advanced springs are used.
Gunter
