Cross Section Area
eaolsen
Cross Section Area
OK, I'm using this thing a lot today.
Does anyone know if it is possible to get the area of a Cross Section from
Pro/E?
Erik Olsen
4 REPLIES 4
bgruman
(To:eaolsen)
Hi All,
I'm sure I'm missing something simple, but it has been a few years since I
have done this and am suffering from "old-timers".
I've created a cross-section of a solid. How do I measure the area of
that section?
TIA!
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
bgruman
(To:eaolsen)
OK, so I can pick the section, right click and select "create a curve".
Then create a "fill" feature using that curve, then measure that new
surface... Do I really need to go to that much work? I thought there
used to be a simple "Measure Area" tool that would let you pick cross
sections...
On Tue, Mar 3, 2015 at 2:37 PM, Bernie Gruman <->
wrote:
> Hi All,
> I have done this and am suffering from "old-timers".
> that section?
> TIA!
> Bernie
> Bernie Gruman
bgruman
(To:eaolsen)
Thank You Keith,
silly me, I was looking under the measure tool.
Bernie
On Tue, Mar 3, 2015 at 2:55 PM, Siddall, Keith <->
wrote:
> If you have a plane going through the section, do a cross section mass
> properties and it gives the area. See below.
> HIH,
> -Keith
> *From:* Bernie Gruman [
> sections...
> wrote:
> Hi All,
> I...
dmartin
11-Garnet
(To:eaolsen)
Btw measuring the area of a closed loop in a sketch is on our wishlist. We had to follow the process you mentioned (complete the sketch, create a fill surface, and then measure the area of the fill surface, just to get the area of the closed loop in the sketch. (We hadn't generated a solid yet, so the Cross Section Mass Properties wasn't available to us.)
David R. Martin II
Senior Mechanical Design Engineer
Amazon Prime Air
