Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
You can go to the view manager in the model view and rename the view, it will show up in the drawing with the corrected name (usually 'A') You can also right click the arrows in the drawing and click "rename" and the view will be updated. Or, you can right click the label and select erase
