Degree symbol in the hole chart
STEVEG
I am creating our ownhole chartfile. Is it possible to get the degree symbol shown or will I have to use DEG?
Steve G
5 REPLIES 5
STEVEG
(To:STEVEG)
Thank yous go to Ron. He gave me the hint.
I knew the code was ALT+0176 so I typed the letters ALT then the plus sign then 0176. I never though actually pressing the ALT key then 0176 would put the symbolin Notepad.
Steve Galayda
When I created the degree symbol in a note the ASCII codes saved were
<soh>$<stx>
I wonder if you could enter these codes through the keyboard:
<ctrl>A $ <ctrl>B
I tested this in a note and if you enter <ctrl>A $ you get a degree
symbol. See if that works.
Or enter it (copy / paste it from a pro-e note) like this: {0:$[1]}
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
STEVEG
(To:STEVEG)
I could not get it to work with your suggestions. I also tried <ctrl-a>$<ctrl-b> In other examples they had the 'a' and 'b' inside the brackets.
Steve G
you should just hit cntrl & a (hold control press a) type your letters or
characters then cntrl & b to end it
x = a depth symbol, n = diameter, the other letters give you various gd&t
symbols, I've never tried the numbers and other characters, but it should
work
here's a pretty good alt symbol list for those who need it
STEVEG
(To:STEVEG)
I thought I tried <ctrl-a>$<ctrl-b> before and it didn't work. Maybe I typed a wrong character. Walt sent what he has in his .hol file and I tried it again and this time it worked. He also said there is a document that PTC has listing all the symbols. Here they are. TPI 104111.
The only thing is the TPI was last updated Oct 2000 but it should still be good.
Description
