Expert Framework
ptc-2167251
Expert Framework
Hello, In the system information it says that the Expert_Framework option is installed, but I don't find the menu in Pro/E Wildfire 4... Do I have to set some options? thanks, bern
Expert Framework is a third party application runs in Pro/E. http://www.buw-soft.com/content/en/produkte/exp_framework_ext.php?p=Mw==&s=Mw==
Thanks Aris. bern
Bernard, EFX only shows up in your menus in an assembly. In part mode or drawing the menu does not appear. Before using it, you must set a project and create an assembly sketch to place steel profiles onto.
Chris Benner
Autodesk ® Expert Elite
Chris is correct of course that EFX is assembly-based only. However, the EFX menu should appear on top in any mode. I think that what's missing the addition of the config option protkdat, whose value should be the path to a .dat file in the EFX installation directory. Because EFX is a Toolkit application, that config option must be defined to make the application available in session. I urge the user to review EFX installation document.
