to create a library
ptc-2245860
to create a library
how to create a library using pro-e wildfire2 an how to use mapkeys in pro-e wildfire2
Can you elaborate on your question some more? What kind of library do you want to set up? Creating and using mapkeys in Wildfire 2.0 is no different from previous versions. Unfortunately, it's difficlut to walk you through the whole process in the forum so I suggest you review the Help Center. It's a good start.
