Extended Exit Logger?
mbraaten
Anyone have any documentation or information about the Extended Exit Logger for Creo or Pro/E? I have searched the PTC.com web site and can only find https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS7633 which is a case solution. There seems to be no documentation or info anywhere. I need to learn more about this tool.
Mike
3 REPLIES 3
Hello???
jkent
(To:mbraaten)
Tech Support will have to supply you the exit logger. Open a case and tell them you want it.
mbraaten
(To:jkent)
Thanks. I'll give that a try.
