Extruded Depth Values
ChrisVanHoeck
2-Explorer
When doing and extrusion, I need a depth value of 1.45, I type this in and hit enter, the value defaults to 1.5. Is there a setting to adjust this?
Try this one: default_dec_places Best regards
This did not work.
sketcher_dec_places: Sets the default number of decimal places displayed for dimensions in Sketcher. The extrusion depth or any other dimension you enter to create 3D geometry is controlled by the default_dec_places option. Give this a try. Hope it works.
Chris Benner
Autodesk ® Expert Elite
There's probably some other option overriding the value for the default_dec_places option, because I tried this one and it worked for me. Best regards.
