File open - sorting
anagnost
File open - sorting
are there any options controlling the sorting of the files on the "file
open" dialog box?
I would like to have a sorting like the "sort by name" that windows do.
Proe WF 4 gives the following sorting:
Below is the sort by name from windows.
Thanks in advance.
Vassilis Anagnostopoulos*
SPIDER SA
Industrial Area - Rodotopi
45500 - Ioannina
Greece
1 REPLY 1
Hi Vassilis-
In the the File->Open window, near the top of the window there is a bar with 'Organize,' 'Views,' and 'Tools.' If you click on the dropdown menu for 'Views' you can choose 'Details' and then you will be able to sort by columns as in Windows.
-Randy
