File syntax or length restrictions
GRS
Are there any file syntax restrictions in Creo2?
Are there any File lenght restrictions in Creo2
Are there any file depth restrictions in Creo2? In other words can you put files many layers deep or is that a problem?
MartinHanak
(To:GRS)
Gerald,
>>> in file names you can use letters (a-z), digits (0-9), underscore and hyphen
>>> max length of filename is 32
>>> max length of directory path is 256 (?)
Martin Hanak
Martin Hanák
MartinHanak
(To:GRS)
Gerald,
Martin Hanak
Martin Hanák
GRS
(To:MartinHanak)
Thanks for your help on this!
Gerald
bliboutet
(To:GRS)
You can used modelcheck
