From mm to inch
ptc-2773989
From mm to inch
Hello, I am a French technician (sorry for my English). I use Pro/E Wildfire 4.0 configured in Milimeters. I have 2 questions: Is it possible to draw in inch? (by modifying the configuration, I suppose ) If yes how do you write dimensions. For example how do you write on the keyboard 1'-5 1/4 "? Thanks Michel
Not applicable
(To:ptc-2773989)
Hello Michel, 1) Set ProE to inch units with EDIT>SETUP>UNITS, select "Inch lbm Second". 2) Convert the dimensions to inches, 1’-5 1/4� = 17.25 or enter as an equation 1*12+5+1/4 Regards-Chris
ptc-2773989
(To:)
Thanks - Chris Michel
