Gerber
bmozley
Gerber
Proe users,
I need some help in creating Gerber files.
I'm using Proe2001.
Brad
bmozley
(To:bmozley)
ProE users,
Does anyone have any knowledge / experience in generating Gerber files
(pho) in Pro E?
Brad
WF3 w7/64
Hi Brad,
The only way I have interfaced Gerber files with Pro-E is to DXF out of Pro, import the DXF into a host program and output the Gerber files from there. In our case the host program is a fabric cutting software called CutWorks.
Brian DeStefano
dgallup
(To:bmozley)
Per the help system:
You can write plot files in Calcomp, Gerber, HPGL2, and Versatec format if you have the Pro/PLOT module. Pro/PLOT is part of the Foundation II license.
mlocascio
(To:bmozley)
Yes indeed THE HELP SYSTEM...
