Gtol with parameter name?
Chris3
20-Turquoise
Other than creating a custom symbol does anyone have any ideas how to create the perpendicularity symbol as shown below?
1 ACCEPTED SOLUTION
James62
(To:Chris3)
While typing text for a new note press Ctrl+A, the cursor should change slightly and then press L key. To get the cursor and the keyboard back to normal press Ctrl+B.
5 REPLIES 5
James62
(To:Chris3)
Chris3
20-Turquoise
(To:James62)
Pretty sure this was meant for another thread.
James62
(To:Chris3)
You think i misstyped? Well, sometimes i do, but not this time.
Just start a new Note in a drawing, place it and hit Ctrl+A then press L then hit Ctrl+B. You will see.
Chris3
20-Turquoise
(To:James62)
Fair enough. I am going to make your answer as correct, but here is what I actually ended up using:
@[ l @]@[Y@]@[B@]
James62
(To:Chris3)
Yup, that's how you type the whole thing, not just the perpendicularity symbol
