Help files not much help: Creo/Pro
I am running into serious issues with help files being way to far out of date.
I am reading things that are clearly wildfire terminology and simply cannot find the Creo ribbon equivalent no matter what I try.
Is there an active group within PTC that shows a level of urgency on fixing the Help files?
I have the same issue with context sensitive help. Most often, when hovering, the context sensitive help just goes off on a tangent.
On the bright side, I found this... a color map for the classic interface when looking for pen table information. This one never even got updated to WF!
This is, after all, a critical UI component of the platform. How could this ever pass quality protocols.
