Help me
KarthiKeyan1
Help me
HIii
i am new here. i am using this soft just in a month ago. i need some help .
1)how i save a model in package and stl format
2)here any option for ,see my model in automatic rotation
Karthi
6 REPLIES 6
Hello
1) "File" --> "Save-as" --> "Type" --> "Shrinkrap" or "STL" (options on shrinkrap for package include Master Merge --> STL
2) By default pro/e does not save animation of parts to rotate in a web page. To animate rotation you have a couple of options.
a) If you have design animation you can use "Application" "Animation" and rotate part to create a movie.
b) Option 2 is create your own pictures with "File" :"Save-as" :"*.jpg" - Multimple ones required to make your own animation.
c) If you own product view it's easy to create animation.
A couple of examples can be found on PTC help page.
Regards
Paul Lalinde
P.S. Welcome to world of PTC.
i got an error message while saving my model in stl format.
that is(you must specify atleast one part or assembly Error414)
what i do??
Which version of Pro/ENGINEER are you using?
P.S. Can you attach a 3D-model, which is saved in the format of STL?
Also, a forum on Creo (including Creo / Elements Pro) is available here: http://communities.ptc.com/community/creo
Hello karthi keyan,
I moved your discussion into the Creo community. This wil be a better audience for you to receive a response to your question
Thank you,
Dan
hiii
plz help me...how i save my model in stl format???
Ya ..No prob guys.. i find out how to save model in stl format ...it's very easy...
