Hello everyone,
In hole table how can I get or hole table gives the holes in ascending order (in terms of diameter i.e, 3,3,4,5,5,6....etc.) (Creo 3.0)
Hi Akshay,
Could you please clarify? I'm not sure what your question is.
Amit
Hi Amit,
hole table shows all the holes in your parts with diameter
If your parts contain min. dia. of 3mm and then say 6mm, 8mm, 10mm etc
so i want in hole table the diameter of holes should show in ascending order for ex. first it show 3mm then 6mm, 8mm etc.
Hole table shows you as per you apply holes if you apply 10mm hole first then it shows you at first no. 10mm hole in hole table.
Hi Akshay,
Unfortunately, it is not possible to sort the order of the hole table.
Amit
If your modeling practices were such that you can reorder the features in the tree for the preferred sort order of the table, you could do that.
You might have to look at consolidation sort priorities as well.
Theoretically, all you need is one M3 before M4 and all subsequent M3's should still consolidate with the 1st instance regardless of where they are in the tree.
I only used WF4 for a short time so I couldn't tell you.
Uncheck the “Use default” box and select Diameter as Sort Column.
Hi Akshay,
Thanks for the update. I had found an article that stated it was not possible. I will need to update it to show the correct behavior.
CS158078 - Is it possible to sort order of Hole Table in Creo Parametric 2.0
Amit
There is a reason we don't always believe PTC's support technicians ![]()
Thanks for updating your records.
