Hi ! I would like to import the old project I did (pk2 files) into Creo 2.0 because I don't want to loose all the work I did.
I would like to know if it's possible to do it .
If yes, how can I do that ???
Thank you a lot for your help !!!!
You cannot do this. That is how they protect their "generous" offering of letting you use it for free.
If you happen to upgrade to the full version, PTC "might" help you by converting them for you.
