How to calculate stress in a specific point?
dpettersson
I have done a static analysis on a beam and I want to calculate the stress at a specific point. How do i do that? I have tried using the dynamic query but I cant pick out the exact point as I want to.
Sketch a curve, with one end at the point that you want to measure, and rerun the analysis. Then you can show a graph of the stress along that curve. It will give you the choice of which end to make "0". Make sure you look at the correct end of the graph.
2 REPLIES 2
Thank you very much!
