Is there some way to change defaut text height and position for new created tables so that i dont have to change it manually each time the table is created?
Thanks in advance
T.
Not sure about position, but table text height is based off the drawing option "drawing_text_height". The value present in the drawing at the time the table is created will determine table text height, the spacing around the text, and the row height. Changing the "drawing_text_height" after the table is created, or adding/copying/moving the table to another drawing with a different value will have no impact. For this reason, I typically adjust the "drawing_text_height" BEFORE creating the table, then change it back to whatever it needs to be afterwards.
Tomas, when you say "position" do you mean text justification/alignment?
Yes i mean aligment
