How to create material library file in CREO?
us
In our material library we have very few materials only.
Now i have to add more material files in creo material library.
Please suggest for creating material library files.
By
uday
1 ACCEPTED SOLUTION
BenLoosli
23-Emerald II
(To:us)
They are simple text files.
Rename an existing one and edit it for your own names and parameters.
There is also an icon to create a new one from within Creo, but it is very generic.
7 REPLIES 7
BenLoosli
23-Emerald II
(To:us)
DenisJaunin
(To:us)
Hello
You have that which is compatible with Creo.
Kind regards.
Denis
http://www.totalmateria.com/page.aspx?ID=Home&LN=FR
BenLoosli
23-Emerald II
(To:DenisJaunin)
Create a new material file with dummy data and then edit it in a simple text editor. See what each set of lines says and does and then add the properties for your materials.
Here is the start part default file we use.
ND_RelParSet_K01 = {
Name = START_MATERIAL
PARAMETERS =
  Name = PTC_MATERIAL_DESCRIPTION
  Type = String
  Default = 'PDM Number, Description 1
Description 2
Description 3'
  Access = Full
  Name = TEMPERATURE
  Type = Real
  Default = 0.000000e+00 F
  Access = Full
  Name = PTC_INITIAL_BEND_Y_FACTOR
  Type = Real
  Default = 5.000000e-01
  Access = Full
  Name = PTC_BEND_TABLE
  Type = String
  Default = ''
  Access = Full
  Name = PTC_MATERIAL_TYPE
  Type = Integer
  Default = 9
  Access = Locked
  Name = PTC_FAILURE_CRITERION_TYPE
  Type = String
  Default = 'NONE'
  Access = Locked
  Name = PTC_FATIGUE_TYPE
  Type = String
  Default = 'NONE'
  Access = Locked
  Name = PTC_MASS_DENSITY
  Type = Real
  Default = 9.900000e+01 lbm/in^3
  Access = Full
  Name = PDM_NUMBER
  Type = String
  Default = 'PROE_SETUP'
  Access = Full
  Name = PDM_NAME
  Type = String
  Default = 'Start Material Name'
  Access = Full
  Name = DESCRIPTION1_U
  Type = String
  Default = 'PDM Number, Description 1'
  Access = Full
  Name = DESCRIPTION2_U
  Type = String
  Default = 'Start Material Description 2'
  Access = Full
  Name = DESCRIPTION3_U
  Type = String
  Access = Full
  Name = DATA_SOURCE
  Type = String
  Default = 'Source for material properties'
  Access = Full
  Name = VERSION
  Type = String
  Default = 'Version of material file'
  Access = Full
  Name = CATEGORY
  Type = String
  Default = 'Material category type'
  Access = Full
  Name = COMMENT1
  Type = String
  Default = 'Material used for setup of start parts.'
  Access = Full
  Name = COMMENT2
  Type = String
  Default = 'Any other comments about material.'
  Access = Full
us
(To:BenLoosli)
Hi
Thanks ben. It is useful for us.
us
(To:BenLoosli)
Hello Ben,
I have created the new material files in our library. And to bring the assigned material in to the parameter,
I have used
* MATERIAL=material_param("PTC_MATERIAL_DESCRIPTION")
In the relation tab. Now my problem is
- When i fill this relation content before assigning the material it will show the below error.
But when i fill this after assigning the material, it will not shown any errors.
I have to save this relation in "start file" itself. So need to type before assigning the material.
Kindly suggest your views.
Chris3
(To:us)
Assign a material, paste in the relation, delete the material. You will still get the error message and a error in the context dialog box that says "WARNING: Some constraint relations are no longer satisfied in YourPART." but it will allow you to save the start part and perform regeneration.
us
(To:Chris3)
Hi Christopher,
What you are suggested here is the exact solution of my problem.
Thanks.
