Knew how to do this in ProE but I cant find it anymore: an option to disable sketch contstraints so I can sketch "freely".
I dont mean hiding the constraints, but the option to disable snapping/aligning to other lines (and I know you can press rmb a few time to get it done in the end..).
Please let me know!
Or, File > Options > Sketcher and untick all of the sketcher constraints assumptions
By holding the Shift key.
