How to join two linked curves in proe?
汐xie
I have two curves liked together, Could I join two curves to one curve? Thank everyone.
6 REPLIES 6
Copy -> Paste Venu
Thanks,venu but, it doesn't work. When I copy the two curves, it becomes two new curves, I only need one curve.
Cant you just create a new sketch and use those as references to give you one sketch ?
You need to use the option "appoximated" when copying. This works with at least tangent continous curves though.
Go to Applications -> Legasy then click the " Insert a datum curve " option, now u can see all the options of datum curve at right side ur display window, in that window select Composite -> Exact -> one by one -> select ur curves do done -> ok Venu
Thanks everyone. It is successfully done according to venu's way.
